Kirby Risk-Mechanical Solutions & Service
714 S. First St.
Lafayette, IN, 47905
765-423-4205
765-423-1686
Indiana Chapter
January 1, 1938
15
  • Vacuum-pressure impregnation equipment (VPI) : Diameter: 6 - 7.99 ft (1.827 - 2.435 m)
October 17, 2011
