Electrical Engineering & Equipment Co.
1808 Delaware Ave.
Des Moines, IA, 50317
515-266-8890
515-266-1181
Midwestern Chapter
January 1, 1938
30
  • Vacuum-pressure impregnation equipment (VPI) : Diameter: 3 - 5.99 ft (0.914 - 1.826 m)
October 18, 2011
