Troubleshooting tips for armature rewinds
April 2003
When an armature is rewound, there is always a slim chance that it may be connected incorrectly. If two coil leads are switched, or if the error results in an armature where each coil closes on itself, normal tests will detect the problem. The trouble arises when the misconnection results in a uniform winding. When that happens, the result may be—in effect—an accidental redesign for a different voltage.
Armatures
Troubleshooting & failure analysis
