Special insulation helps create larger oven when motor is too big to fit
April 2000
We are cleaning a motor that is too large for our bake oven. In the past, we have placed the motor in front of the oven with the doors open, and draped a tarp over the frame to trap the heat.Is there a better way to dry it out? Most readers in our industry have used variations on that method to dry the windings of a motor that simply won't fit in the bake oven. There is a better way. Use Energy Shield - the insulation home builders install between the exterior frame and siding or brick. It is a stock item in most lumber yards and construction-supply superstores. Energy Shield is basically just a hard foam material with a layer of aluminum foil on both sides. The insulating value (R-29) is phenomenal, so it is ideal for building a temporary oven. Use Energy Shield to box the motor, including the top. Seal the joints with aluminum duct-tape. The motor may be placed in front of the shop oven, or an alternate heat source may be used to force air through the temporary oven.
Repair procedures and tips
Service center equipment
