A.C. Electric Corp.
40 Target Industrial Cir.
Bangor, ME, 04401
207-945-9487
207-945-0114
New England Chapter
January 7, 1978
23
  • POLYPHASE MOTORS OVER 600 VOLTS
  • TRACTION
  • Vacuum-pressure impregnation equipment (VPI) : Diameter: 6 - 7.99 ft (1.827 - 2.435 m)
November 10, 2011
