Applied Dynamics Corp.
36 Butternut St.
Greenfield, MA, 01301
413-774-7268
413-773-7919
New England Chapter
October 29, 1991
35
  • Vacuum-pressure impregnation equipment (VPI) : Diameter: 8 - 9.99 ft (2.436 - 3.045 m)
