Bigelow Electrical Co., Inc.
1 Pullman St.
Worcester, MA, 01606
508-852-5000
508-853-2010
New England Chapter
January 1, 1938
  • POLYPHASE MOTORS OVER 600 VOLTS
  • ROTATING FIELDS 10 kW AND OVER
