Polyphase motors less than 50 hp (37 kW)
Polyphase motors up to 200 hp (150 kW)
Polyphase motors 200 hp (150 kW) and over
Polyphase motors with formed coils
Polyphase motors over 600 volts
Wound rotors
AC generator rewinding less than 50 kW
AC generator rewinding 50 kW and over
Brush shifting motors
DC motors or generators less than 10 kW
DC motors or generators 10 kW and over
Rotating fields less than 10 kW
Rotating fields 10 kW and over
Armature rewinding
Air-cooled rebuilding
Air-cooled rewinding
Oil-filled rebuilding
Oil-filled rewinding
Welder transformer rewinding
Auto transformer rewinding
Dynamic balancing
General machine shop
Metal spraying
Pump repairing
Rotor rebarring
Electromechanical field servicing
Electronic field servicing
Switchgear 600 volts
Switchgear over 600 volts
Vibration analysis
Laser alignment
Portable balancing
Thermography
Under 125 hp (93 kW) @ 1800 rpm
125 to 250 hp (93 to 186 kW) @ 1800 rpm
251 to 500 hp (187 to 373 kW) @ 1800 rpm
Over 500 hp (373 kW) @ 1800 rpm
Polyphase electric motors
Gear motors, speed reducers
Adjustable-speed drives
Power transmission equipment
Generators
Electric motor controls
