Bader Al Mulla & Brothers Co., WLL, Engineering Group
Plot 83-84 St. No. 10 Shuwaikh Ind'l Area
Shuwaikh, 13002
Kuwait
965-4815077
965-4839725
European and World Chapter
June 3, 1988
45
  • DC MOTORS OR GENERATORS LESS THAN 10 kW
  • AIR-COOLED REBUILDING
  • DYNAMIC BALANCING
  • Vacuum-pressure impregnation equipment (VPI) : Diameter: 10 ft (3.046 m) and larger
