Al's High Tech, Inc., dba Al's Electric Motor Service
135 Northfield Rd.
Bedford, OH, 44146
440-232-7090
440-232-8798
Greater Cleveland Chapter
May 19, 1980
  • BRUSH SHIFTING MOTORS
  • DC LIFTING MAGNETS
  • GENERAL MACHINE SHOP
  • Vacuum-pressure impregnation equipment (VPI) : Diameter: 3 - 5.99 ft (0.914 - 1.826 m)
