Crowder, Jr. Co.
2184 Industrial Dr.
Bethlehem, PA, 18017
610-866-8081
610-866-6358
Quaker City Chapter
August 11, 2003
22
  • DYNAMIC BALANCING
  • GENERAL MACHINE SHOP
  • ELECTROMECHANICAL FIELD SERVICING
  • ELECTRONIC FIELD SERVICING
  • VIBRATION ANALYSIS
  • Vacuum-pressure impregnation equipment (VPI) : Diameter: 3 - 5.99 ft (0.914 - 1.826 m)
  • Area regularly serviced (radius from plant) : Less than 50 miles (80 km)
September 28, 2011
