Delaware Electric, Inc.
2149 Bushkill Park Dr.
Easton, PA, 18040
610-252-7803
610-252-5255
Quaker City Chapter
November 17, 1971
6
  • SERVO
  • Bake oven : Less than 4 x 4 x 4 ft (1.2 x 1.2 x 1.2 m)
  • Area regularly serviced (radius from plant) : Less than 50 miles (80 km)
