G.I. Electric Co., Inc.
944 Sheridan St.
Williamsport, PA, 17701
570-323-6147
570-323-5160
Quaker City Chapter
November 5, 1948
6
  • Dynamic balancing equipment : Less than 500 lbs (227 kg)
  • Largest crane or hoist capacity : Less than 2 tons (1,815 kg)
September 28, 2011
