Lubbock Electric Co.
1108 34th St.
Lubbock, TX, 79411
806-744-2336
806-744-5690
6
Southwestern Chapter
October 6, 1948
70
  • Hazardous Area Equipment Rebuilding
  • Cryogenic
  • Vacuum-pressure impregnation equipment (VPI) : Diameter: 6 - 7.99 ft (1.827 - 2.435 m)
  • Area devoted to service work : 50,000 sq. ft (4,646 sq. m) and over
September 30, 2009
