Advanced Electric Equipment Service, Inc.
2411 Larson St.
La Crosse, WI, 54603
608-781-2627
608-781-2628
North Central Chapter
September 27, 1984
  • Vacuum-pressure impregnation equipment (VPI) : Diameter: 3 - 5.99 ft (0.914 - 1.826 m)
  • Dynamic balancing equipment : Less than 500 lbs (227 kg)
October 25, 2011
