A&A Electric Motors & Pumps Sales & Service, Inc.
1320 W. Central Blvd.
Orlando, FL, 32805
407-843-5005
407-843-5006
2
Southeastern Chapter
March 25, 2010
  • DC MOTORS OR GENERATORS LESS THAN 10 kW
  • ROTATING FIELDS LESS THAN 10 kW
  • ROTATING FIELDS 10 kW AND OVER
  • ARMATURE REWINDING
  • Area regularly serviced (radius from plant) : Less than 50 miles (80 km)
  • Area devoted to service work : Less than 2,000 sq. ft (186 sq. m)
March 25, 2010
