Bob White Electrix
79 St. Georges Rd.
Corio, VIC, 3214
Australia
61-3-5275-1017
61-3-5275-3204
Australasian Chapter
January 20, 1975
65
  • POLYPHASE MOTORS OVER 600 VOLTS
  • WOUND ROTORS
  • Vacuum-pressure impregnation equipment (VPI) : Diameter: 6 - 7.99 ft (1.827 - 2.435 m)
  • Area devoted to service work : 50,000 sq. ft (4,646 sq. m) and over
November 14, 2011
