Electric Motor Service, Ltd.
8835 60 Ave.
Edmonton, AB, T6E 6L9
780-496-9300
780-496-7629
Western Canada Chapter
July 17, 1989
70
  • POLYPHASE ELECTRIC MOTORS
  • Vacuum-pressure impregnation equipment (VPI) : Diameter: 10 ft (3.046 m) and larger
October 24, 2011
