Ainsworth, Inc.
456 Franklin Blvd.
Cambridge, ON, N1R 8G6
519-620-8003
519-620-9115
Ontario Chapter
June 1, 1999
16
  • Vacuum-pressure impregnation equipment (VPI) : Diameter: 6 - 7.99 ft (1.827 - 2.435 m)
September 20, 2010
