Ainsworth, Inc.
131 Bermondsey Rd.
Toronto, ON, M4A 1X4
416-751-4420
416-751-1276
Ontario Chapter
March 12, 1951
40
  • Hazardous Area Equipment Rebuilding
  • Vacuum-pressure impregnation equipment (VPI) : Diameter: 6 - 7.99 ft (1.827 - 2.435 m)
October 3, 2011
