Apparatus Serviced By Members (except for transformers)
Apparatus accepted by Service Center (EASA Member) from a Customer for repair or servicing will be warranted to operate satisfactorily for the time period as defined below. Apparatus accepted by Service Center from a Customer for specific repairs, or for the repair and replacement of specific parts only, are warranted only as to the extent that such specific repairs are performed or parts furnished by the Service Center. All Warranties in addition to any other conditions or requirements contained herein, including the general provisions, are provided with the condition that the Customer operates the equipment with competent supervision, does not exceed rated load or capacity of equipment, and has normal usage and operating conditions.
Types of Limited Warranties are as follows:
A. Complete Apparatus
1. Mechanically Rebuilt, Electrically Tested
2. Electrically Rebuilt, Mechanically Inspected
3. Mechanically and Electrically Rebuilt
4. Reconditioned
B. Component of Apparatus
1. Mechanically and Electrically Rebuilt
2. Reconditioned
Definitions of Types:
A-1. Complete Apparatus - Mechanically Rebuilt, Electrically Tested
The Service Center Warrants that the apparatus has been dismantled, inspected, parts cleaned, lubricated, windings dried, varnished and baked as required, all mechanical tolerances (including sleeve bearings if a component of the equipment) brought to Manufacturer's tolerances or EASA Recommended Practice, including the replacing of all anti-friction bearings with new bearings (if such bearings are a component of the equipment), dynamically balanced, assembled, tested, and painted. Such Service Center Warranty shall extend for a period equal to the Manufacturer's Warranty, but not to exceed ninety (90) days from date of shipment. Such Service Center Warranty shall be limited to the liability provided in the general provisions which are a part of the Service Center Warranty. In the event that the Service Center and the Customer mutually agree that a bearing(s) should not be replaced or rebabbitted, the bearing(s) is (are) not warranted.
A-2. Complete Apparatus - Electrically Rebuilt, Mechanically Inspected
A-2A. Totally Electrically Rebuilt
The Service Center Warrants that the apparatus has been dismantled, inspected, parts cleaned, lubricated, all windings replaced with new winding(s) composed of new insulation and wire in accordance with EASA Recommended Practice, assembled, tested, and painted. Such Service Center Warranty shall extend for a period of ninety (90) days from the date of shipment on all items except the new electrical winding(s) which the Service Center Warranty shall extend for a period equal to the Manufacturer's Warranty, but not to exceed one (1) year from date of shipment. Such Service Center Warranty shall be limited to the liability provided in the general provisions which are a part of the Service Center Warranty.
A-2B. Partially Electrically Rebuilt
The Service Center Warrants the apparatus as stated in A-2A, except for apparatus where multiple windings are involved (e.g.: slip ring motors, direct current motors, synchronous motors); and the Service Center Warranty for multiple winding apparatus applies only to the new winding(s) installed by the Service Center.
A-3. Complete Apparatus - Mechanically And Electrically Rebuilt
A-3A. Totally Mechanically and Electrically Rebuilt
The Service Center Warrants that the apparatus has been dismantled, inspected, parts cleaned, lubricated, all mechanical tolerances (including sleeve bearings if a component of the equipment) brought to Manufacturer's tolerances or EASA Recommended Practice, all windings replaced with new windings composed of new insulation and wire in accordance with EASA Recommended Practice, including the replacing of all anti-friction bearings with new bearings (if such bearings are a component of the equipment), dynamically balanced, assembled, tested, and painted. Such Service Center Warranty shall extend for a period equal to the Manufacturer's Warranty, but not to exceed one (1) year from date of shipment. Such Service Center Warranty shall be limited to the liability provided in the general provisions which are a part of the Service Center Warranty. In the event that the Service Center and the Customer mutually agree that a bearing(s) should not be replaced or rebabbitted, the bearing(s) is not warranted.
A-3B. Partially Electrically Rebuilt and Totally Mechanically Rebuilt
The Service Center Warrants the apparatus as stated in A-3A, except for apparatus where multiple windings are involved (e.g.: slip ring motors, direct current motors, synchronous motors); and the Service Center Warranty for multiple winding apparatus applies only to the new winding(s) installed by the Service Center.
A-4. Complete Apparatus - Reconditioned
The Service Center Warrants that the apparatus has been dismantled, inspected, parts cleaned, lubricated, windings dried and varnish treated as required, dynamically balanced, assembled (replacing anti-friction bearings with new bearings, if applicable), tested, and painted. Such Service Center Warranty shall extend for a period equal to the Manufacturer's Warranty, but not to exceed ninety (90) days from date of shipment. Such Service Center Warranty shall be limited to the liability provided in the general provisions which are a part of the Service Center Warranty.
B-1. Components Of Apparatus - Mechanically And Electrically Rebuilt
The Service Center Warrants that the component of apparatus has been inspected, all mechanical tolerances brought to Manufacturer's tolerances or EASA Recommended Practice, windings replaced with new windings and insulation in accordance with EASA Recommended Practice, varnish treated as required, dynamically balanced (if applicable), and painted (if applicable). Such Service Center Warranty shall extend for a period equal to the Manufacturer's Warranty, but not to exceed ninety (90) days after date of shipment. Such Service Center Warranty shall be limited to the liability provided in the general provisions which are a part of the Service Center Warranty.
B-2. Components Of Apparatus - Reconditioned
The Service Center Warrants that the component of apparatus has been inspected, windings dried and varnish treated as required, dynamically balanced (if applicable), tested, and painted (if applicable). Such Service Center Warranty shall extend for a period equal to the Manufacturer's Warranty but not to exceed thirty (30) days from date of shipment. Such Service Center Warranty shall be limited to the liability provided in the general provisions which are a part of the Service Center Warranty.
General Provisions
The foregoing warranties will not apply to defects, occurring within the warranty period, resulting from misuse by customer or by reason of improper installation, application, circuit protection, assembly or repair of the apparatus by others subsequent to service by the Service Center.
If the apparatus does not operate in accordance with the foregoing Warranties, the Service Center will refund the price of the goods or service or will provide for the reworking or replacing of the apparatus or parts, at the Service Center's option, to cause it to so operate for no additional charge to the Customer, at the Service Center's place of business, and during the Service Center's regular working hours. Transportation of the apparatus, if required, will be paid for by the Customer. The Service Center's liability for any breach of the foregoing Warranty shall be limited to such refund, reworking or replacement and, in the case of claims arising out of the Service Center's inspection of apparatus, to the charge made for such inspection. Service Center shall not be liable to customer, or to any other person, for any indirect, consequential, or other kinds of damages arising out of this transaction.
Disclaimer
Any implied warranty of merchantability or warranty that the goods or services can be used for any particular purpose, or any other expressed or implied warranty, except as herein provided, is hereby disclaimed and excluded from this warranty.
No representative of Service Center has any authority to modify these warranties in any manner.
Any action for breach of any of the foregoing Warranties must be brought within two years after the cause of action has accrued.
