Delom Services, Inc.
13065 Jean Grou St.
Montreal, QC, H1A 3N6
514-642-8220
514-642-8598
Quebec & Maritimes Chapter
November 30, 1967
108
  • Hazardous Area Equipment Rebuilding
  • Cryogenic
  • Vacuum-pressure impregnation equipment (VPI) : Diameter: 10 ft (3.046 m) and larger
  • Area devoted to service work : 50,000 sq. ft (4,646 sq. m) and over
October 17, 2011
