J.R. Perreault & Fils, Ltee.
340 Lucien Thibodeau St.
Portneuf, QC, G0A 2Y0
418-286-6666
418-286-4774
Quebec & Maritimes Chapter
September 2, 1988
23
  • POLYPHASE MOTORS OVER 600 VOLTS
  • Vacuum-pressure impregnation equipment (VPI) : Diameter: 8 - 9.99 ft (2.436 - 3.045 m)
  • Area devoted to service work : 50,000 sq. ft (4,646 sq. m) and over
September 28, 2011
