Delom Services, Inc.
1505 Des Tanneurs
Quebec City, QC, G1N 4S7
418-687-1100
418-687-0516
Quebec & Maritimes Chapter
January 27, 1987
35
  • ARMATURE REWINDING
  • TRACTION
  • Vacuum-pressure impregnation equipment (VPI) : Diameter: 10 ft (3.046 m) and larger
January 6, 2011
