EBI Electric, Inc.
2250 90e Rue
St. Georges, QC, G5Y 7J7
418-228-5505
418-228-5630
Quebec & Maritimes Chapter
July 18, 1991
  • Burnout oven : Less than 4 x 4 x 4 ft (1.2 x 1.2 x 1.2 m)
  • Area devoted to service work : Less than 2,000 sq. ft (186 sq. m)
November 3, 2011
