EMS/Seimec, Inc.
8455 Rue Champ D'Eau
St. Leonard, QC, H1P 1Y1
514-325-0941
514-325-0994
Quebec & Maritimes Chapter
November 18, 1987
35
  • POLYPHASE MOTORS OVER 600 VOLTS
  • AC GENERATOR REWINDING LESS THAN 50 kW
  • Vacuum-pressure impregnation equipment (VPI) : Diameter: 8 - 9.99 ft (2.436 - 3.045 m)
January 6, 2011
