Anstee & Ware, Ltd.
St. Andrews Rd.
Avonmouth, Bristol, BS11 9HS
United Kingdom
44-117-9820081
44-117-9823501
European and World Chapter
January 12, 1979
70
  • SERVO
  • TRACTION
  • Vacuum-pressure impregnation equipment (VPI) : Diameter: 8 - 9.99 ft (2.436 - 3.045 m)
  • Area devoted to service work : 50,000 sq. ft (4,646 sq. m) and over
