Single-phase motors
Polyphase motors less than 50 hp (37 kW)
Polyphase motors up to 200 hp (150 kW)
Polyphase motors 200 hp (150 kW) and over
Polyphase motors with formed coils
Polyphase motors over 600 volts
Wound rotors
AC generator rewinding less than 50 kW
AC generator rewinding 50 kW and over
Brush shifting motors
ISO 9000 Series registration.
DC motors or generators less than 10 kW
DC motors or generators 10 kW and over
Rotating fields less than 10 kW
Rotating fields 10 kW and over
Armature rewinding
DC welders - rotating
DC welders - static
Servo
Traction
Hermetic
DC lifting magnets
Air-cooled rebuilding
Air-cooled rewinding
Oil-filled rebuilding
Oil-filled rewinding
Welder transformer rewinding
Auto transformer rewinding
Dynamic balancing
General machine shop
Hermetic compressors
Metal spraying
Pump repairing
Rotor rebarring
Air compressors
Combustion engines
Electromechanical field servicing
Electronic field servicing
Printed circuit board repairing
Switchgear 600 volts
Vibration analysis
Laser alignment
Portable balancing
Thermography
Under 125 hp (93 kW) @ 1800 rpm
125 to 250 hp (93 to 186 kW) @ 1800 rpm
Single-phase electric motors
Polyphase electric motors
Gear motors, speed reducers
Adjustable-speed drives
Generators
