A 1 Pumps & Motors, Ltd.
Unit 6/46 Hobill Ave., Manukau
Auckland, Auckland
New Zealand
64-9-2639913
64-9-2639914
New Zealand Chapter
August 28, 1997
7
  • HERMETIC
  • ELECTROMECHANICAL FIELD SERVICING
  • POLYPHASE ELECTRIC MOTORS
  • PUMPS
  • Largest crane or hoist capacity : Less than 2 tons (1,815 kg)
September 30, 2011
