Electric Motor Solutions, Ltd.
24 Ra Ora Dr., E. Tamaki
Auckland, Auckland
New Zealand
64-9-2747233
64-9-2740300
New Zealand Chapter
July 9, 1991
7
  • DC MOTORS OR GENERATORS LESS THAN 10 kW
  • Cryogenic
  • Dynamic balancing equipment : Less than 500 lbs (227 kg)
September 14, 2010
