Alfanar Technical Services
P.O. Box 35388
Jubail Industrial City, 31961
Saudi Arabia
966-3-3418777
966-3-3415639
European and World Chapter
December 13, 2001
225
  • OIL-FILLED REWINDING
  • Vacuum-pressure impregnation equipment (VPI) : Diameter: 8 - 9.99 ft (2.436 - 3.045 m)
October 14, 2011
