Ashoor Electric Motors
2652 Alhada St., Alfaisalya Dist. (2) Off Madina Rd. Kilo-9
Jeddah, 21452
Saudi Arabia
966-2-6391687
966-2-6393261
European and World Chapter
August 5, 1991
34
  • WOUND ROTORS
  • ROTATING FIELDS 10 kW AND OVER
  • HERMETIC
October 21, 2010
