A&J Works, Inc., dba Andrews Electric Motor Works
1603 Mono Dr.
Modesto, CA, 95354
209-521-0030
209-521-6429
7
Northern California Chapter
February 3, 1977
  • POLYPHASE ELECTRIC MOTORS
  • ELECTRIC MOTOR CONTROLS
  • Vacuum-pressure impregnation equipment (VPI) : Diameter: 3 - 5.99 ft (0.914 - 1.826 m)
  • Dynamic balancing equipment : Less than 500 lbs (227 kg)
  • Lathe equipment : Less than 16 in (40 cm)
September 28, 2009
