Boulder Electric Motor Co.
3865 Walnut St.
Boulder, CO, 80301
303-443-1331
303-443-6178
Number of employees:
Rocky Mountain Chapter
February 25, 1976
  • Lathe equipment : Less than 16 in (40 cm)
  • Largest crane or hoist capacity : Less than 2 tons (1,815 kg)
  • Area regularly serviced (radius from plant) : Less than 50 miles (80 km)
September 30, 2009
