Leppert/Nutmeg, Inc.
113 W. Dudley Town Rd.
Bloomfield, CT, 06002
860-243-1737
860-242-8283
Connecticut Chapter
February 1, 1957
32
  • BRUSH SHIFTING MOTORS
  • Cryogenic
  • DYNAMIC BALANCING
  • Vacuum-pressure impregnation equipment (VPI) : Diameter: 6 - 7.99 ft (1.827 - 2.435 m)
October 7, 2011
