Power supply considerations when building a large growler
July 2017
Tom Bishop, EASA Senior Technical Support Specialist
When considering building a large growler for testing armatures and rotors, the initial decision typically is to select a kVA rating. A primary reason for this is that the growler will need to be connected to a power supply of sufficient ampacity at the supply voltage. To help simplify a complex design process, four kVA ratings have been selected for this article. One of the selected ratings should fit the needs of most service centers.
This article covers:
  • A design example
  • Determining turns and wire size
  • Building the core
  • Determining coil dimensions
Service center equipment
