Cox Electric Motor Service, Inc.
1409 Truimph Dr.
Urbana, IL, 61802
217-344-2458
217-344-2464
Number of employees:
7
King Coal Chapter
February 16, 1987
  • SINGLE-PHASE MOTORS
  • HOIST
  • DC LIFTING MAGNETS
  • DYNAMIC BALANCING
  • ALIGNMENT
  • Dynamic balancing equipment : Less than 500 lbs (227 kg)
  • Largest crane or hoist capacity : Less than 2 tons (1,815 kg)
November 10, 2009
