Don Abney, Inc.
500 Bridget Dr.
Patterson, LA, 70392
985-395-5131
985-395-5139
Mid-South Chapter
January 7, 2000
27
  • AC GENERATOR REWINDING LESS THAN 50 kW
  • ARMATURE REWINDING
  • TRACTION
  • GENERAL ELECTRICAL CONTRACTING
  • Vacuum-pressure impregnation equipment (VPI) : Diameter: 3 - 5.99 ft (0.914 - 1.826 m)
August 27, 2010
