Understand O-rings in Submersible Pump Maintenance & Repair Process
Publication:
Pumps & Systems
June 2014
Author:
Inspect compression surfaces thoroughly to help ensure leak-free repairs
A leak rate of one drip per minute equals about a liter (quart) of water in three days. For an O-ring on a submersible pump, that is a major problem. O-rings are often used for static seals on submersible pumps. Understanding what makes a good static seal and what causes one to leak is important for pump maintenance and repair technicians.
The effectiveness of an O-ring static seal depends on the dimensions of the mating parts, the surface finish of the mating parts and the characteristics of the elastomeric O-ring. The focus of this article is the dimensions and condition of the mating parts.
Topics covered in the article include:
  • Dimensions
  • Identification of critical surfaces
  • A case study
