Industry Representation
EASA staff and volunteer committee members represent your interests on a variety of standards-making committees that affect our industry. Below is a list of organizations with EASA representation.
ASAIEC | IEEE | MDM | NEMA | NFPA | UL | Green Motors Practices Group
Acoustical Society of America (ASA)
  1. ASA ASC-S2 Work Group 15 - Shaft Alignment Methodology (acting chair)
IEC logo
International Electrotechnical Commission (IEC)
John Allen, Sheppard Engineering Limited
  1. Working Group for Introduction of IEC 60079-19 into IEC Ex Scheme
  2. TC31 Management Committee for IEC 60079-19
Tom Bishop, P.E., EASA Senior Technical Support Specialist
  1. Maintenance Team 60079-1 for IEC 60079-1, Electrical Apparatus for Explosive Gas Atmospheres
  2. TC31 US TAG for IEC 60079, 61779, 62013 and 62086
Chuck Yung, EASA Senior Technical Support Specialist
  1. TC2 working group
  2. 60034-8 Rotating Electrical Machines; Terminal Markings
  3. 60034-11 Rotating electrical machines – thermal protection
  4. 60034-17 Motors fed from converters
  5. 60035-2-34 Standards Technical Panel for Hermetic Refrigerant Motor-Compressors
  6. IEC 60034-27 Rotating electrical machines – Part 27: Partial discharge off-line measurements on the stator winding insulation of rotating machinery
IEEE logo
IEEE Working Groups
Jim Bryan, EASA Technical Support Specialist
  1. IEEE 1068 Standard for the Repair and Rewinding of Electric Motors for the Petrochemical and Other Process Industries
  2. IEEE P3004.8 Recommended Practice for Motor Protection in Industrial & Commercial Power Systems
Mike Howell, EASA Technical Support Specialist
  1. IEEE 1415 Guide for Induction Machinery Maintenance Testing
  2. IEEE Standard 11-2006, Rotating Electric Machinery for Rail and Road Vehicles
  1. IEEE 303 Recommended Practice for Auxiliary Devices for Rotating Electrical Machines in Class I, Division 2 and Zone 2 Locations and Class II, Division 2 and Zone 22 Locations
  2. IEEE 841 Standard for the Petroleum and Chemical Industry - Severe Duty Totally Enclosed Fan-Cooled (TEFC) Electric Motors
  3. IEEE 1017-2013 Recommended Practice for Field Testing Electrical Submersible Cable
  4. IEEE 1018 Recommended Practice for Specifying Electric Submersible Pump Cable - Ethylene Propylene Rubber Insulation
  5. IEEE 1019 Recommended Practice for Specifying Electric Submersible Pump Cable - Polypropylene Insulation
  6. IEEE 1068 Standard for the Repair and Rewinding of Electric Motors for the Petrochemical and Other Process Industries (chair)
  7. IEEE 1349 Motors in Hazardous Locations
  8. IEEE 1415 Guide for Induction Machinery Maintenance Testing (Note: Voted to allow this controversial guide to expire)
  9. IEEE 1458 Recommended Practice for the Selection, Field Testing and Life Expectancy of Molded Case Circuit Breakers for Industrial Applications
  10. IEEE 1566 Standard for Performance of Adjustable Speed AC Drives Rated 375 kW and Larger
  11. IEEE 1584 Guide for Performing Arc-Flash Hazard Calculations
  12. IEEE 1683 Guide for Motor Control Centers Rated Up to and Including 600v AC or 1000v DC with Recommendations Intended to Help Reduce Electrical Hazards
  13. IEEE 1716 Recommended Practice for Managing Natural Disaster Impact of Key Electrical Systems and Installations in Petroleum and Chemical Facilities
  14. IEEE 1814 Recommended Practice for Electrical System Design Techniques to Improve Electrical Safety
IEEE Standards Association—Standards Review and Ballot
  1. IEEE C57.12.00 Standard for the General Requirements for Liquid-Immersed Distribution, Power, and Regulating Transformers
  2. IEEE C57.12.34 Standard Requirements for Pad-Mounted, Compartmental Type, Self Cooled, Three Phase Distribution Transformers, 10 MVA and Smaller; High Voltage, 34.5 kV Nominal System Voltage and Below; Low Voltage, 15 kV Nominal System Voltage and Below
  3. IEEE C57.12.59 Guide for Dry-Type Transformer Through-Fault Current Duration
  4. IEEE C57.12.90 Standard Test Code for Liquid-Immersed Distribution, Power, and Regulating Transformers
  5. IEEE C57.94 Recommended Practice for Installation, Application, Operation, and Maintenance of Dry-Type Distribution and Power Transformers
  6. IEEE C57.106 Guide for Acceptance and Maintenance of Insulating Oil in Equipment
  7. IEEE C57.637 Guide for the Reclamation of Mineral Insulating Oil and Criteria for Its Use
  8. IEEE 56 Guide for Insulation Maintenance of Electric Machines (Combines IEEE 56 and IEEE 432)
  9. IEEE 95 Recommended Practice for Insulation Testing of AC Electric Machinery with High Direct Voltage
  10. IEEE 112 Test Procedure for Polyphase Induction Motors and Generators
  11. IEEE 117 Standard Test Procedure for Thermal Evaluation of Systems of Insulating Materials for Random-Wound AC Electric Machinery
  12. IEEE 1068 Standard for the Repair and Rewinding of Electric Motors for the Petrochemical and Other Process Industries
  13. IEEE 3002.7 Recommended Practice for Conducting Motor-Starting Studies in Industrial and Commercial Power Systems
  14. IEEE 3002.8 Recommended Practice for Conducting Harmonic-Analysis Studies of Industrial and Commercial Power Systems
  15. IEEE PPIC DCS Subcommittee (Drives & Controls Systems)
Green Motors Practices Group logo
Linda Raynes, EASA President and CEO
Motor Decisions Matter logo
Motor Decisions Matter (MDM)
Marketing & Industry Awareness Committee
 Chair
NEMA logo
National Electrical Manufacturers Association (NEMA)
  1. ANSI C50 Rotating Machinery Committee (Alternate: Tom Bishop, P.E., EASA Senior Technical Support Specialist)
  2. NEMA MW 1000
  3. NEMA Codes and Standards (C&S) Task Force on Refurbishing Products
NFPA logo
National Fire Protection Association (NFPA)
  1. NFPA 70B Electrical Equipment Maintenance
UL logo
Underwriters Laboratories (UL) Standards Technical Panels
  1. 506 Low Voltage Transformers
  2. 1004 Standard for Electric Motors (7 sub-categories)
  3. 1446 Systems of Insulating Materials
  4. 1562 Transformers, Distribution, Dry-Type over 600 volts
  5. 2111 Standard for Overheating Protection for Motors
  1. 448 Standard for Pumps for Fire Protection Service
  2. 674 Electric Motors and Generators for Hazardous Locations
  3. 778 Standard for Motor-Operated Water Pumps
  4. 840 Standard for Insulation Coordination Including Clearances and Creepage Distances for Electrical Equipment
  5. 1434 Standard for Thermistor-Type Devices
  6. 1450 Standard for Motor-Operated Air Compressors, Vacuum Pumps and Painting Equipment
